Hi Albert,
You discovered another Trajectory Planner bug. (how many is that now ?). It was more related to a specific combination of multiple segments than a small facet size. It isn't easy to describe but basically during the optimization process the TP was able to look at 3 segments and logically deduce that a high velocity could be used on the middle segment, but then in a special case forgot to fully optimized the neighbor segment which resulted in a discontinuous velocity and a negative time. The neighbor segments will now be optimized fully.
Please copy this DLL which contains the TP to your KMotion429\KMotion\Release directory to see if it resolves the issue.
